I have a of planer curves. And I need to select certain branches with their curve data. The slit tree feature is not working, because it converts the list into texts.
Does anyone have a solution?
Split Tree can’t convert curves into text, that -unwanted- conversion must be happening somewhere earlier in your definition, on the left of where the screenshot was taken
by the way, this initial component is a Data Parameter, which can contain anything (strings as well as curves) so the presence of that container does not define where the problem has started: the problem was already present at the beginning of this screenshot
I’m pretty sure if you pass that Data Parameter into a Curve Parameter or a Curve Length component, you will get the very same error before getting even close to Split Tree
please attach your definition -no internalized geometries required- if you want to know more
