DataTree Selection Rule {0;?}
I am trying to select all branches that start with 0.
I am following the Rules from here.
When I put {0;?} in a panel and plug it into Path, it seems to work fine.
When I put the Panel or Path into TreeBranch, it fails to convert Text to Path.
What am I missing?
They work slightly differently.
Tree branch is nice because you can just use a quick 0,0 to get {0;0}.
Tree Branch only accepts genuine paths; that is actual integers in the path notation. Split Tree accepts the notation with wildcards.
Thank you,
That makes more sense. I knew there was something simple that I was missing with this component.
