Tree branch_Data conversion failed from Text to Path
Does someone know how to solve this? I want to extract branch 6.
Thanks a lot!!!
What is the error it gives you?
I’m having a similar issue here. As soon as I use any of the Data Tree Selection Syntax (DataTree selection rules - Grasshopper) like * or ?, Grasshopper doesn’t recognize it as a Path anymore and gives me the error “1. Data conversion failed from Text to Path.”
Any idea why this is happening?
EDIT: Sorry, I already found the solution: This kind of syntax apparently only works with components like “Split Tree” and not with “Tree Branch”.
