Section Tools clipping plane outputting wireframe when printing
In the 8.2 version, the section tools clipping plane is printing the wireframe view on larger models
For eg, my model is of 672 polysurfaces and 2 meshes
all checked for naked and non manifold edges and got 0 errors and all have been declared valid objects.
The print preview is absolutely perfect and as needed
but, when outputting through rhino pdf, it outputs the wireframe view
Hi Shaan,
Can you run SystemInfo in the command line and post the result? Thanks!
Sorry, I already downgraded and reinstalled 8.1 and it’s working in that
I will be happy to share the system info of 8.1 for my system so that you could have a look at potential plugins
I have changed and ommited some of the personal information as this is not my personal machine and a company machine … hope this doesn’t cause too much trouble
Wherever I have changed something, I have added a highlight of what it was supposed to be
LICENCE OCCLUDED FOR COMPANY PRIVACY
I am still a college intern so don’t wanna get into trouble TvT
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 9-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.42
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 9-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.42
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-12-2023
Driver Version: 31.0.15.3742
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users(USER NAME)\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.1.0
C:\Users(USER NAME)\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Walkie (95abcca2-5ce3-486a-9592-32464857f282)\4.14.0.0\Walkie.rhp “Walkie” 4.14.0.0
C:\Users(USER NAME)\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2024.1.72.0\XR.Rhino.Plugin.rhp “Fologram for Rhino” 2024.1.72.0
C:\Users(USER NAME)\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\2.2.0.180\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
C:\Users(USER NAME)\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
these are the files of a different project showing the same problem
8.1 output.pdf (323.8 KB)
8.2 output.pdf (2.7 MB)
A quick test on a Mesh and Polysurface Raster print is OK. Can you post a small example file that demonstrates the behavior? I’m running an early release of 8.3, there have been work in the printing as of late.
The raster has lineweight problems similar to early 8.0 releases, I will post those files as well
I can send the same file, as this is just a personal project I put on 8.2 for testing purposes
I accidentally sent the wrong pdf
Correct 8.2 problem file.pdf (4.2 MB)
this is the exact file that was causing the problems… I think the original file will be more helpful
I changed your view to shaded and printed Raster with no issues. Are there different steps you are taking?
yes, I mostly need line drawing for my works so, I am taking techincal viewport drawings and sometimes the pen view as well for quick snaps
I’m successful in both those display modes as well. If there was an issue in 8.2 it may have been resolved 8.3, can you confirm?
I am currently working on my drawing set but will tell you in a while if it is working or not
