Section style to detail view
Hi all,
I’m having a problem with section styles - if you edit an object’s section style (rather than the layer) or sometimes even move that object onto a layer with preset section settings, it no longer applies that section style in the detail view unless you change display modes to something other than what the detail was.
This shows the lower section of the wall at my usual working display mode
This is how it appears in any other display mode, for every detail
Very annoying as I set my detail views to the display mode I want to use as a final output while I work
