Rhino 8 upgrade - clipping section styles no longer work on any view
I just updated to the latest version (Version 8 (8.13.24317.13002, 2024-11-12))
Every single view in the project that was using section styles now no longer recognises them or any clipping plane lines, doesn’t matter what view I am in or what thickness I adjust things to be. This is a huge disaster for the project I am on.
I am having to trace over all sections with a thicker lineweight to try imitate the section (with this tight deadline)
So far section styles have been so buggy as to be almost unusable for actual work. I would rather stick with drawing on top of detail views in layout with thicker lineweights then constantly risk having something bug out or stop working.
It’s done this to every single file I have… Can you urgently send a download to revert back to the older version? This is such a massive bug!!
Hi user384, sending you en 8.12 for mac.
Can you run the systemInfo command in rhino and post the result? We haven’t seen any similar reports, any additional info would be helpful. Thanks
Perhaps there are bugs in common with this post?
