Scripting PopUpToolbar command fails
Hi All,
I am trying to call user-defined toolbar with PopUpToolbar command via scripting and can’t get it to work - both in RhinoScript or Python Rhinoscript syntax, the toolbar shows up for a split second but then disappears, not letting the user to pick any icons from it.
Here are the code samples:
  • RhinoScript:
Call Rhino.Command("_PopUpToolbar " & chr(34) & "default.scale" & chr(34))
  • Python
rs.Command("_PopUpToolbar default.scale")
All works fine if I just use command or macro, but not the scripts. Any ideas how to make it work, or maybe this is a bug?
Second question: is there a way to get a list of all loaded toolbars that are available to popup? The RhinoScript toolbar methods seem to be obsolete and I can’t get them to produce that (or maybe doing it wrong way?). Python or RhinoCommon would do as well.
Thank you,
–jarek
Hi @Jarek,
I’ve logged the issue - https://mcneel.myjetbrains.com/youtrack/issue/RH-54212
– Dale
