Scripting ShowToolbar in Rhino8
In Rhino 7 I had various scripts with commands like:
ShowToolbar Jim
ShowToolbar Block
Now in Rhino 8, I just get a popup window to select the toolbars I want to show.
How can I have a script turn on all the toolbars I want, so I don’t have to use the pop up?
I tried _Showtoolbar and it just gives me the popup as well.
Screenshot 2024-05-14 165938
Hi James - use the ‘dash’ version of the command “_-ShowToolbar” to bypass the dialog.
Hi Pascal,
Thanks for the quick answer! That works great.
If I have toolbars with the same name in different libraries, is there a way to specify which one I want with the command line?
I imported all my Rhino 7 toolbars because I modified a lot of buttons, so now I end up with duplicate names, but one is in my “Jim” library and one is in “Default” I guess I can go rename all my old ones, but it would be convenient if my macro could just specify which library.
Hi James - the -Toolbar command (again with a dash) will help - it lets you specify a library. HOwever, I am not sure that the recent tuneup that lets this work correctly is in the current release - you can get the very latest by changing ‘Update frequency’ in Options > Updates and Statistics page to ‘Service release candidate’.
Hi Pascal,
The -Toolbar command seems to work just fine on the version I have. It asks for the library and then the toolbar, Perfect!
Thanks!
Hi Pascal,
I’m trying to open Toolbar Groups using the -ShowToolbars command without any luck. Would you know if that’s possible?
Thanks!
