I have written a script (SquishBack 3d) by useing Ai .It needs a lot of improvements.
I hope the team will help me improve its performance.
It has been tested on rhino 7 & 8
Thank you in advance
SquishBack 3d LiveSync.py (46.0 KB)
Note:
frist : use The command squish to flatten the original mesh and It is preferable to increase mesh polygon For a better result .
second : this script Transfers curves-Mesh-polysurface-extrusion & surface
and you have 4 option in command bar You can choose between them
Note:
this script transfers the objects from the flatten mesh to original mesh and in the other direction from original mesh to flatted mesh
Hello everyone
I hope any one have Comments or suggestions after use this script to share to Discussions or changes
Dear all
This is a new version of script LiveSync that supports movement in any direction and rotation. and olso It needs a lot of improvements I hope everyone to write down their observations and any problems they faced while working with this script to help me improve its performance .
and i hope Rhino-devs to support us to add this command to rhino .
I think it will be useful to everyone
Did you know about Shapemap?
To me it seems is already doing what your doing but with much more features already available.
I haven’t worked on grasshopper yet, but let me try Shapemap frist.
Does anyone have any feedback? Is the script working properly?
I think it would be better to change the name from [squishback 3d] to [flow along mesh] to be more consistent with what it does.
