Question about Squish Back
The SquishBack command returns curves and points on the 2-D pattern to the original squished 3‑D shape.
Is there a way or tricks to choose surfaces or mesh object .
Thanks.
Hello - sorry, I do not understand the question yet… can you explain a little more?
Rh5.3dm (4.6 MB)
that’s what FlowAlongSrf does.
you need a base surface that shares the same structure of the target surface. Ideally, the same amount and distribution of contol points to avoid deformation
