Scaling Dots
Just spoke to Jerry at Tech Support about this. Was having trouble scaling dots on my layout page. Help file says that you can change their size in their Text Options. This does not seem to work though. Talking with Jerry, we stumbled on to the Text dot font size pull-down under Non-scaling objects in the Linetypes and Line Widths panel on the Print dialogue box. This worked, but their is no mention of this in the Help file. And… why would it be listed under Non-scaling objects when the Help file says they are scaling?? :slight_smile:
Hi Cosmas - Dots can be scaled in their Properties once made, or in the Dot dialog as they are created - any of that work for you?
Hey Pascal,
No, that’s what we discovered with Jerry. The only way they seem to be scalable is through the the Text dot font size pull-down under Non-scaling objects in the Linetypes and Line Widths panel on the Print dialogue box. Changing the Height in the Dot Properties box doesn’t seem to have any effect. The Text dot font size pull-down in the Print dialogue box overrides it.
Thank you.
When you print out a pdf - that’s when you realize the dots have not changed…
@Pascal, did this make sense? :slight_smile:
