Scaling an object in increments.. in 3d space
Is it possible to scale an object ( not flat on a plane ) by certain increments…? Like snapping every .1mm
Example: a 2mm diamond ( that is a block ) that needs to go to 2.1mm … as if gumball was oriented to the object and you could scale 3d in .1 increments.
Thanks
Hello- if you set SnapSize to 1/2 the increment, and turn on GridSnap, Gumball should work that way.
Great tip! thanks!
