I used to use
rs.Command ("_-SaveRenderWindowAs "+FileName)
to save all of the passes inside the V-ray window. Since swapping to the new V-ray and Rhino 6 it seems to only save the RGB pass.
Does anyone know how to revert to saving all of the passes?
Kind regards,
dale
(Dale Fugier)
3
I’ve moved this to the Rendering V-Ray category.
– Dale
I’m bumping this thread. How do you save all channels!?!?
I can solve your PNG problem at least, all you have to do is specify the filename as a png like zo
saveLocation = filePath + str(frameName) + “.png”
rs.Command("-_SaveRenderWindowAs \n""+saveLocation + “”\n")
