Hi there guys I’m new to V-ray and I can’t figure it out how can I save in alpha channel.I use rhino .I set the material reflection and refraction to all channels >Affect channels to all channels -
S
sometimes I save as png as alfa from the render frame - but It doesn’t save nothing …
When I render I only see black ,I also use fur …so any of you know how to save in alpha channel in V-ray 3.4 I will much appreciate if u give me a answer …I rly need this one fast for my school project tomorrow.
I believe it is a bug and will be fixed in 3.6. if you use no background you can and use Photoshop to create one. Here is what I was told, but it does not work. I did play with the render an animation and it work.
"Hi,
This is a known issue and our developers are currently working on a solution, which should be implemented in an upcoming hotfix update.
In the meantime, as a temporary workaround, you could also use the ‘Save Image’ option (Asset Editor > Settings > Render Output) prior to initiating a render process. When the render is complete, the produced image will be automatically saved along with all render channels."
