Hi @pascal,
i have a Rhino 7 file which uses a custom global hdri environment for reflections and lightning under skylight. When i save it with the option Save Textures checked and send it to a collegue, the file opens with a different environment i’ve saved it with. The correct file is however in the …_embedded_files folder. It uses the default Studio environment instead after reopening.
The file is quite large and exhibits another bug with missing fonts. It changes the command line text to a different font. Can i sent this via PM for inspection ?
thanks,
c.
