Save rhino file to 0.05mm binary
with smoothness i mean tesellation, there are several examples of printed pieces where the poligons are visible in the surface due to a lower polycount which is configured by the tolerance when exporting to stl.
an exagerated example:
then you will get pieces like this:
where the poligons are clearly visible in apparently smooth surfaces.
