Same hatch in two layouts with different colors
Hi everyone,
I’m stuck with trying to generate two drawings in two different layouts.
I’m using a Clipping Plane to create a hatch. The goal is to show (and print) that same hatch differently depending on the layout:
  • Layout 1: hatch appears red
  • Layout 2: hatch appears black
The object/hatch is already on the layer I marked, and in the Layer settings you can see that a different print color is set for each layout. However, Rhino doesn’t display or print the hatch color the way I expect.
You can also see my current settings in the screenshots.
How can I fix this?
Thanks in advance!
is Print Display on the top view and not the bottom? We might need to see the file if that’s not the case.
SP_IA_Standert_Vorlage_Workingfile.3dm (9.5 MB)
I hope that helps :slight_smile:
Hi Jesse -
Thanks for that file.
The feature request to have section hatch patterns take the print color is on the list of things to implement and I have added your thread:
→ RH-78947 Print Color for Sections Not Available
RH-78947 is fixed in Rhino WIP
