HATCH pattern colour print issues
I am using Rhino 8 for Macbook. I have comprised my drawing, most have which has different colour hatch lines for different materials. It’s showing up the colour when it’s on print display but when I print it the colours are faded to almost black, if not just black, I can’t tell. I have tried two ways of doing the hatch and still have the same result-
  1. My walls are a layer in which I have changed the ‘section style’ to custom in the model layers. The pattern colour is set to blue and the background to white.
  2. I have added the hatch in the layout where i drew a rectangle over the section cut. Command- Hatch. And have changed the pattern colour there.
When i click print display it shoes up as blue and when i ‘print’ even the little thumbnail shows it as a vibrant blue but when the PDF is downloaded / it’s sent to the plotter it’s printing as black. Also to note the spacing of the hatch (pattern scale) does not make a difference.
Hi Chelsea,
Please run SystemInfo in Rhino and post the result.
Can you post a small example file that illustrates the issue as well? Thanks!
