I was developing a GH Definition in Rhino 7 and everything worked fine. Then I opened the same file in Rhino 6 and one component (Offest Curve) seems to fail.
Please find attached the GH File. BrokenInRH6.gh (10.6 KB)
I believe it has to do with different Rhino Common References? Is this a bug or a “to expect” behaviour… which would mean I will always have to double check if my GH created in V7 is working on the other V6… and vice versa?
The offset component created with GH for Rhino7 have a default internalized WorldXY plane in the plane input.
But that plane is missing when the file is read by GH for Rhino6. It’s empty.
If you create a offset component from GH for R6 the plane is there, like in R7 …
To avoid this uncertainty, use a PlaneXY component and connect it to the Offset plane input.
The problem seems just this…
are there any other known differences between Rhino 6 and Rhino 7 GH (Since it’s the same GH release, I figured both are using the same core libraries in the background)
I’m not sure, I don’t know.
If I were you, I’d develop my script on the Rhino version it will run.
Also, I’d expect to have less problem with forward compatibility than backward, I think it’s safer to develop in RH6 and maybe then run the script in RH7 than vice-versa.
