in Rhino 6 circle offset maintain circlulare shape correctly, however when I offset circle in Rhino 7 it deforms into ellips then a twisted ellips.
Rhino 7, something is wrong circle does not offset to circle. instead, it offset to ellips shape.
in plane xy it offset correctly but in other planes in mess up the offset.
In Rhino 6, circle offset to circle in all planes.
I even tried copy paste the GH definition from Rh6 to Rh7 and it gave the same wrong results.
could anyone try this definition on his Rhino 7 and check if it’s my machine problem or it is a bug in Rhino 7.
deformed circle shape in Rhino 7 after offset
thank you in advance
