_RunPythonScript takes up to 20 seconds to react on first call.
This is when the PC was rebooted, or Rhino slept overnight.
After the first call the reaction time is normal.
The irritating thing is on first call there is no info, like “Initializing Python…” or something.
Rhino is simply unresponsive.
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.17
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 11-29-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.29
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-29-2023
Driver Version: 31.0.15.4629
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\6.0.0.0\XNurbsRhino7.rhp “XNurbs”
The delay (a few seconds) was already there in Rhino 7, but in Rhino 8 it got a lot slower. To solve the problem, I have a small startup script which I gave an alias LoadPython to and it runs when Rhino starts:
import scriptcontext as sc
import Rhino
print "Rhino Version V{} - Python loaded!".format(rs.ExeVersion())
This seems also to work in V8, if I restart the computer, open Rhino, make an object and then run a script from an alias or button on it, it runs instantly.
As a couple of my scripts use Grasshopper components and that is also very slow to load, I added this line later:
import ghpythonlib.components
Anyway that seems to help. Opening ScriptEditor for the first time after a restart is still slow, and VERY slow after a new version install.
That sounds typical after a new version installation… if you launch ScriptEditor. I have never seen that just using already programmed tools that run via _-RunPythonScript
When you run a command in software, you expect an immediate response.
If immediate execution is not possible, a progress bar would be good.
“Initializing Python - please wait” + progress bar
When the software seems to do nothing, it is confusing and frustrating.
We do have a progress bar on almost any form of running any scripts that required python initialization (e.g. RhinoPythonScript, ScriptEditor, or Grasshopper script component.
Is it possible that your Rhino window might be smaller and the progress bar is not visible?
This is a test that I just rain in my local SR7 build. See the progress bar at the bottom right:
Do you use any of scripting features in Rhino? If yes, and there are chanegs to the runtime, the scripting tool that you’d use (script editor, grasshopper component) will perform a one-time update when a new Rhino is installed.
Save the script somewhere.
Create an alias “LoadPython” (or whatever else you want) using _-RunPythonScript "Full path to script" (include the .py extension)
In Options >Files, put the name of the alias in the box “Scripts to run at startup”
That’s it…
