just down loaded the trail version, my program opens , but is very unresponsive and slow , i have enough ram , and CPU , why is this ?
Run the Rhino command SystemInfo and post the results. That will provide system information which will assist someone to help you.
Rhino 7 SR20 2022-7-12 (Rhino 7, 7.20.22193.09001, Git hash:master @ 9b19bfdb8c343dd6fa8df3514068defd72273d6f)
License type: Evaluation, build 2022-07-12
License details: Stand-Alone
Expires on: 2022-10-23
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 9.9Gb)
Computer platform: LAPTOP - Plugged in
Primary display: Intel(R) HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y).
> Integrated graphics device with 2 adapter port(s)
Primary OpenGL: NVIDIA GeForce GT 540M (NVidia) Memory: 1GB, Driver date: 5-1-2017 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 382.05
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 5-1-2017
Driver Version: 22.21.13.8205
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.20.22193.9001
Your video drivers are exceedingly old and your system isn’t really up to snuff for Rhino 7, not enough RAM or VRAM, your GeForce is 11 years old.
So do u recommend new grafix card ?
Well you can’t upgrade a laptop GPU, but to start…there are probably other things lacking if the GPU is that ancient.
new laptop ?
Intel(R) Core™ i5-2410M CPU @ 2.30GHz 2.30 GHz
Again that dates to 2011, so…??? Is it even able to run at full speed anymore, is the cooling ventilation plugged up with dust or the fan not working so well?
Older versions of Rhino were specifically designed to used on whatever old computer you have lying around in some office that’s not even CAD-oriented. That’s not the case since upgrades to OpenGL support in V6, it is no longer optimized to run on a potato, you should have at least a half-decent “gaming” machine.
not a terrible idea.
read this-
Since it is a hybrid, make sure, in the NVidia control panel, that you are in High Performance mode.
