vixvic
(Victor)
October 13, 2018, 11:34am
1
Hello there!
I’m getting issue trying to define a ruled surface between two curves in grasshopper.
Here is what I got :
We can see the junction between the two appears in a green line.
However, I would like to place it in horizontal as we can do in rhino shown in the following image :
Could someone have a clue and could help ? Thank you,
You’ll have to adjust the seam point on the inner curve to be halfway the left edge, rather than between the left edge and the bottom left fillet arc.
vixvic
(Victor)
October 13, 2018, 12:55pm
3
DavidRutten:
thank you for your advise, how could you do that with grasshopper ?
Adam_M
(Adam Mounsey)
October 13, 2018, 1:01pm
4
This conversation should be helpful.
Dear bloggers
i am new grasshopper user,experincg problems with ruled surface or loft.
I need to build a surface between two different curves: one is a triangle and one is a circle. The problem i have is that surface is twisted and i don’t understund why… it would be very kind if you help me. I am attaching some pictures for better understanding.
[3] [2] [1]
Thanks a lot.
vixvic
(Victor)
5
Ok, thanks a lot. I manage to do it using curve closest point and seam.
