Ruled Surface between two curves
Dear bloggers
i am new grasshopper user,experincg problems with ruled surface or loft.
I need to build a surface between two different curves: one is a triangle and one is a circle. The problem i have is that surface is twisted and i don’t understund why… it would be very kind if you help me. I am attaching some pictures for better understanding.
3
Thanks a lot.
You will need to most likely flip one of the curves or change the seam of one of the curves.
I already tried to flip the surface and work on seam… it still has a twist.
I don’t understand how the “ruled surface” works and the direction of extrusion, that should be gradually from the triangular section to the cicle along the Z axis…
Best to upload your gh file, internalising any data, so people can take a better look. If you’re not sure how, take a look at number 3 in the link below.
No, flip one of the curves (flip curve component), then make the surface.
i did not know. It would be much better, thanks a lot :slight_smile:
pillarparametric.gh (16.3 KB)
The easiest way is to use Mr Pryor’s very useful “Align Curve Seams” component from Pufferfish.
Edit: I noticed a small error in the file I uploaded, so here it is again.
pillarparametric_Rev2.gh (16.3 KB)
i needed this plugin before :joy::joy::joy: , top, thank you so much
You can do it using gh native components (see the attached file for an alternate option), but Align Curve Seams makes it a bit more straight forward.
pillarparametric_Rev2Alternate.gh (18.8 KB)
Thank you very very very much, yes i saw. the next step is to understand if there is a math fuction that describe better the curvature. i definitly need more controll points and more sections.
Here the pillar detail.
