rs.Command() Suppress echo problem
Hi-
In the python code below I try to suppress the echos on the command line but it still shows the “command:” echo.
Is it possible to suppress this aswell?
import Rhino
def MergeEdge():
    ArrObject=rs.GetObjects("Select Parts",16)
    rs.EnableRedraw(False)
    for srf in ArrObject:
        rs.Command("_MergeAllEdges _SelId "+ str(srf) + " _Enter",False)
    rs.EnableRedraw(True)
if __name__ == "__main__":
    MergeEdge()
Try preceding the command name with _NoEcho.
– Dale
Hi Dale
It Didn’t work.
I modified the commanline but still the command echo appear.
rs.Command("_NoEcho _MergeAllEdges _SelId “+ str(srf) + " _Enter”,False)
See attached files
–Nico
MergeAllEdges.py (323 Bytes)
MergeAllEdges.3dm (230.6 KB)
I am not seeing anything echoed to the command line, other than the Select Parts prompt.
What am I missing?
– Dale
I’m seeing the same as Nico.
A Command: is printed for each repeat of the loop.
Also, an additional Select Parts. Press Enter when done: is printed after Enter is pressed.
For example, after window-selecting 4 surfaces at once and pressing Enter, this is printed:
Select Parts:
Command:
Command:
Command:
@Nico_de_Meester
A workaround is:
def MergeEdge():
    ArrObject=rs.GetObjects("Select Parts",16,select=True)
    rs.Command("_MergeAllEdges",False)
    rs.UnselectAllObjects()
Steve
Hi Dale
I got the same as what Steve showed.
When you want to merge for example 100 parts you probably got 100 Command: lines in the history.
But the workaround off Steve works.
So I am happy.
Thanks for you reactions.
Nico
