I am scripting Export and Import commands from GHPython.
But the blnEcho option when scripting those two does not work the same like when scripting other commands.
rs.Command("_Sphere 0,0,0 5 “,False)
rs.Command(”_SelLast “,False)
rs.Command(”-Export " + file_name + " x e p e" + " _EnterEnd",False)
the command prompts are visible in rhino in the export step.
** file_name is a path …\test.obj
As opposed to doing this , rs.Command("_Point 0,0,0 ",False) where no command prompts are echoed, as it should be.
Thanks for your reply @dale …
One other question that is a bit related, when using this method to script commands, if I want to “set” command line toggle options to a specific state, rather than toggling them every time I am accessing them, is there a way to accomplish that?
So for example rs.Command("_Rotate c “,False) would toggle between Copy = Yes and Copy = No, is there a way to make sure the value is either all the time?
