We are using the below scripting command. I specified “echo = false”. But it’s not reflecting while running our application.
bool isSuccess = Rhino.RhinoApp.RunScript("_-Export " + filePath + " Enter", false);
Thanks,
Pushpa
Thanks,
Pushpa
Hi Pushpa,
The echo parameter only work to suppress ‘get’ generated prompts. It does not suppress messages printed by commands - calls to RhinoApp.WriteLine() for example.
If you are trying to hide the results of scripting a command, you might consider clearing the command history windows when your scripting command finished. You can do this by calling RhinoApp.ClearCommandHistoryWindow().
– Dale
