rs.Command echo
Hi there,
I use the following line in my script and I still get a message in Rhino command window that sais:
“1 curve added to selection” How can I avoid this message?
rs.Command("_Connect" + " SelID " + str(bsLineJC1) + " SelID " + str(bsLineHC1) + “_Enter”,False)
I could use Rhino common without replacing rs.Command.
Hi @onrender,
Turning off command echo disables an prompts you might see that are generated by GetObject, GetPoint, etc. It does not, however, disable statements printed to the command line.
– Dale
I think I understand. Prompts and statements are two different things,
