Rotation based on another geometry rotation
Hello everyone,
I am trying to model those emergency door overhead mechanism, but I am struggling to make the lower connector (yellow) rotation based on the upper connector (blue) rotation. I tried using vector rotation, but it seems that something is missing.
Anyone know how to do this movement uppon the rotation of the upper connector geometry? I drew how the right rotation should be in yellow.
Door mechanism doubt.gh (64.2 KB)
This might not be what you’re looking for. Also this GH definition is a MESS!!! but the approach is easy to explain at least. If you create circles with the radius between the hinges of the arms, you can use their intersect point(s) to get rotation. This almost works. It might work actually I think I just moved something hence the slight mis-alignment. A lot of these types of hinges have one hinge that can pivot, or an arm that can change length. They tend to bind at some point otherwise. Modeling that however…
This type of ‘challenge’ comes up in architecture often with the dreaded bi-folding doors. I’m not sure if this approach would work, but it’s the same problem: rotating something that’s also being rotated (and/or moved). The real solution is probably a fancy trig equation. I think I did that in Revit years ago - even had the door handle move with it.
For this I’ve had to make 0.10 the minimum rotation. You’d need a switch statement to do something a little different as it approaches zero. Basically the circles thing their only intersection is their start point (I think) so it changes the point on us and the hinge goes out of place.
Door Example.gh (17.1 KB)
I like the approach.
What many people don’t know (and this is important for “redneck modelers”) is that Math does NOT define Geometry.
The keyword here is define.
Geometry defines math.
I hate to see people feel intimidated just because they don’t master the math of GEOMETERIC problems, if you see what I mean. But even if you do master the math, it is geometry that defines math (if anyone wonders why teachers try to “illustrate” the math… What they’re doing is going back to definitions.)
:innocent:
It really is :grimacing:, I am fairly new to grasshopper, if you have any advice on how could I do this less messy I am open to it :grin:
Yeah, I really need the door to be able to open fully. Maybe if the rod instead of being a block had the lenght based on the circles, the circle could be bigger and achieve the full 90 degree rotation.
I was expecting something based on linked vectors to make the translation movement.
I can clean this up and explain it better but I’ll need a few days. This at least proved the concept but a nice clean version would be nice (and much easier to understand).
Last minute I internalized all the data so who knows what it looks like on other people’s computers.
The door will open fully (I think) if we change the number slider’s max to 90. That’s one of the easier problems to solve. The fully-closed situation… I’ll have to put some thought into that.
I’ll also see if I can align those pieces better. They don’t have to be blocks once they’re internalized. Just having them as breps might be better maybe they’ll preview nicer?
Hi Leo,
Where you have a problem like this it pays to isolate the issue you have to solve (here the movement of a linkage) from the straightforward stuff (e.g. a slab door). Just produce a geometric abstraction of the linkage and get that to work before adding all the decoration that hangs off it. That way you don’t waste time constantly finding and altering elements that are irrelevant to the problem.
HTH
Jeremy
EDIT:
By focussing on the geometry rather than the form, the linkage solution reduces to something like this:
Which is much easier to work with!
Linkage abstraction (not to scale).gh (16.7 KB)
Cleaned up version coming. Just figuring out how to present it. Hopefully better than this haha:
The solution to the circle/intersection point was to find the longest length… in this case I just used the door’s main hinge, use that as a start point and then compare the distance from there to the intersects. Whichever one is farthest away happens to be the one we need. Works perfect in this case but might not always work for other hinge types.
This hinge is also closer to the design in the picture. The one hinge point will be attached to the door header/jamb.
Having the pivot arms not be parallel actually makes the circle-intersect solution possible (well… we’d need another python script otherwise… if less than…. etc….). There must be a way to find the longest curve without adding like 800 nodes? This python script could really just be a few lines if it had to.
I’ll post an ‘internalized’ version but also make sure not to save over the non-internalized one.
Here it is. Tested it out as well as I’m unfamiliar with internalizing data. But it appears to work as intended and it works in an empty file. I’m using the “mm Large Objects” template but I don’t think it matters (only for scale).
Door Example 2 - Internalized.gh (25.5 KB)
Excellent video Joseph - I’m going to make that. Thanks for sharing.
I went a little overboard with this one. Partly because I needed to test out a few Grasshopper features at some point and this ended up being the perfect chance to do that. Apologies if I pulled the focus off Leo’s original request/inquiry. At least you have a nice example to work with. Please ask if you have any questions (and while the script is fresh in my head).
I’m not much of a Grasshopper user (more into just programming), so any “should have done this instead of that” is encouraged and appreciated. I’ll be using a very similar approach in future GH definitions as my workflow is very depending on blocks. Maybe I’ll build a simple engine or something that would be fun!
Note that the definition is laggy even on my RTX 4070 laptop with a fast processor (Ryzen 9). I think that improving the preview capabilities of Grasshopper would go a long way. Maybe not ‘rendered’ but something that looks nice and doesn’t require huge amounts of resources.
Door Example 2 - With Materials - Internalized.gh (724.9 KB)
Door Hinge Example 2 - For internalized version.3dm (5.5 MB)
Even comes with a bonus free door handle:
I really needed to test out a few things: Internalizing stuff, working with blocks, previewing… To be honest it’s a lot of work for what you get in the end. I’m sure it’s not so bad if you use Grasshopper at least 2/3 times a week.
I’m impressed by the humility expressed in that statement so took a look. Unfortunately, the GH canvas is so large that when I zoom out to 100%, I can see only a very small part of it, so it’s difficult for me to understand.
I tried enabling the Profiler to find the lag but failed to see it? Any idea which part is slow?
(‘Display | Canvas Widgets | Profiler’)
Oh well… :man_shrugging:
You modelled everything outside grasshopper?
Yes. Creating basic geometry inside grasshopper is pretty straight forward. But as things get more complex you need to have a really really good reason to generate stuff inside grasshopper.
I do have all the linework maybe I can extract that really quickly.
What I’ve done here is “internalized data” - you right-click on the object to do that. In this case I’ve done this so that someone can basically just take the file and see what it does without needed a 3DM. Also, if I don’t “internalize data” you would have to go through the process of “setting one point”, “setting one curve”, etc… And lastly, it makes things look cleaner - otherwise the original objects need to stay in their original positions and you don’t get that nice clean representation (you can move everything of course among other things).
I’m still figuring out the best way to use block instances. If I internalize them they don’t update when the file’s block definition is updated. If I don’t internalize them I have to place them where I want them at the start
Really nice modelling! I thought it was modelled in rhino because of such detail! Could you upload the gh file? I would like to see the reasoning behind and how you solve some geometry such as the upper mechanism curved arm and the filleted edges.
Edit: Sorry, I thought I asked if you had modelled it inside grasshopper and not oustide grasshopper.
That grasshopper file is attached to my post above - about 4 or 5 posts up now.
I’m attaching yet another version complete with Rhino file - Just the linework basically. It’ll make it easier to see what I did but ‘easier’ doesn’t mean it’s easy to dissect a script that someone else made. Plus the way I’ve done this means that if you add/delete a single object you have to adjust all the list indexes to get the right objects going to the right places. I think it would have been better to run more operations in parallel. I think this can be improved both in the way of readability and extendibility. And for that reason I wouldn’t be too concerned about the GH file itself (but ask any questions if you have them I can explain every node) and rather just use a similar approach. Starting off as simple as possible as Jeremy has shown above might be a good plan.
Door Hinge Example 2.3dm (78.8 KB)
Door Example 2.gh (18.6 KB)
If you
The animation can be improved if no blocks are exploded after the transfromation. Orienting meshes from the block plane to a transformed plane is the main reason why it runs faster…
If the data structure stys intact, the materials can be retrieved from the initial blocks so no sorting is necessary at the end of the definition.
Door Example 2 - With Materials - Internalized orient meshes.gh (727.3 KB)
Since this is so in my head I realized I’m being lazy by not whipping up a much clearer version. This one also helps make clear why they have an angle on the arm that stays fixed to the door jamb/header. You can adjust the angle via the number slider from 5 to 35 - you can take the minimum limit off. If you set it to less than 5 you really start to see the problem. The model still works just the speed at which the arm goes to its neutral position accelerates drastically as it approaches the fully-closed position. Not sure what this would do in real life but I see why they have some angle:
15 degrees seems like a very realistic angle but you can play around with it:
In this one I’ve just moved the geometry over 2000 so you can see just the main parts working, but left (almost) everything visible so you don’t have to unhide (un-preview) a bunch of crap to figure it out. I think this will be a better learning tool than what I posted as I both had to get my head back into Grasshopper and not get carried away with the presentation related stuff.
Door Closer Hinge - Focus on Linework and Function.3dm (96.2 KB)
Door Closer Hinge - Focus on Linework and Function.gh (19.3 KB)
Thank-you very much for this. Just from the screen shots alone I think I’m going to learn quite a bit.
