Rotating extrusion
Hello, so the extrusion follows those two curves, but everytime i try to rotate the geometry, the line just keeps moving which the geometry follows moves instead of just the geometry. I just would like to rotate the geometry along the line. I hope that makes sense.
extrude to.gh (17.8 KB)
not very clear :slight_smile:
if you are trying to rotate each Geometry on its plane, easiest is to rotate the plane on which the Rectangle thas is being extruded is created:
extrude to_Re.gh (19.5 KB)
thank you, this is exactly what I meant, I’m sorry my wording was unclear.
