Hi, I’m really new to Rhino and Grasshopper, so my problem is most likely a very simple one, but what is going on essentially is that I’m creating a simple outdoor bench, and I wanted to use the vertical lines seen in the image to make square supports for the back part of the bench. My problem is that i can’t figure out how to extrude them in such a way to have each of them be parallel to the seat.
The most promising thing I’ve tried is forming a pipe out of each line, then creating a bounding box for each pipe, and selecting the same lines as the plane for the bounding boxes. This seems to vertically incline the boxes to the angle i want them to, but they’re still all rotated to the x and y axes, and not parallel to the seat. So I guess if you can tell me how I can rotate the boxes around the seat, the problem would be solved too.
Attached images show the lines im trying to use, and the bounding boxes (with a top view showing how they’re not aligned with the curved bench)
