Hey everybody. I`m very new using Grasshopper and rhino so I would appreciate your support and help on this question.
I need to make a rectangle following a group of lines projected on a surface. This rectangle shape is created based on a specific size of splits I did by multiplying a domain.
What is happening right now is that the perpendicular frames I created are making the splits not flat to the surface. I will send pictures to explain.
Can you guys help me orient it to be flat with the surface under it? I thank you a lot for the support.
The current layer were the referenced lines are in the Rhino model is “00_NEW_curves_splits”.
The grasshopper script that controls it is in the file highlighted with a red box
GRASSHOPPER_TEST_SPLITS.gh (16.4 KB)
GRASSHOPPER_TEST_SPLITS.3dm (689.8 KB)
