In rhino 7 I am able to hold Ctrl + Shift and use my arrow keys to rotate my planar views. I assume this is rotation of the camera but this is the only way i know how to do this in rhino 7.
now in rhino 8 I can not find a way to do this same thing.
About that, 8 is working the same as 7 here…
Maybe you enabled nudge without ALT key?
If you have it like this:
Unfortunately when i do this the view is rotating around the z axis and not the C plane axis. my nudge direction is set the to the c plane axis.
not sure why i am seeing different results
Thank you!
This worked for me
So the solution above worked for me but where do i set the increment in division for the camera rotation?
Hi Matt -
That would be this one, no?
That was my thought too but here is an image of my settings where that is set to 15 degrees. This should move my screen 90 degrees in 6 movements and this is not happening.
even tried to reset to default settings
Hi Matt - that setting is not degrees but divisions of a circle - 15 degrees would be 24 there.
Thank you Pascal and team. Reading error thinking it was degrees. This makes it work when its on 60
