If you have a building level with elevation 0 and with cut plane 1400, then setting up a PlanView with a Cut Plan elevation lower than 1400 will make room tags dissapear and setting that PlanView’s Cut Plan Elevation to anything above 1400 will turn the text into ‘unfilled’ text, with an outline, but only if that room tag text exceeds/portudes past the room boundary. See example file
VisualARQ can keep texts as texts in plan views as long as they are not covered by any other geometry. Otherwise the text (like it happens with the space label in one of your examples) is generated as curves. This is a known limitation.
On the other hand, the second case, where you have changed the cut plane elevation of that plan view, should not make the space label disappear from the plan view. We will revise this.
