Why the text became white when i generate a plan view?
But the text area is fine.
Thank you very much
Thank you very much
That’s because both texts behave different, the text area of a space is always above but the other one could be occluded by other objects and that could take too much to calculate.
Try to use real time views as much as possible instead, because there is where we are putting more effort. Select the level you want to see and click Set Plan View to Viewport.
ok i will do like this thank you
