I have a contoured site and struggling to make correct roads with cut and fill in rhino…
On a heavily contoured topography, I want to analyze portions of land that cross a set limit say 1:10 and accordingly make road with cut or fill and for portions of land that are within the limit the road should be made on the natural topography with minimum intervention
Attached are the pictures of the contour land and the proposed road
Hi Martin,
Yes too many discussion on the same topic..Did a lot of research as well, still stuck for a easy and reliable solution specifically for surfaces
I was specifically following this one as it had the same query but couldn’t find any conclusive answer
