Hi @Eugen,
This feature is in progress. It takes the objects in the Rhino layout to the dwg layout. If you are using the Hidden display mode inside the detail view, it creates a 2D vectorial projection of the objects in the model which are visible in the detail view to export this to the dwg model.
So, in the final dwg you will have your objects in 2D in the model and your detail views in the layout. Yes, we are using the dwg exporter and yes, we are using our own projection engine (vaPlan/Section view) internally as well.
