Hi everyone,
One of the most requested features is export plans and sections, like curves, to AutoCAD DWG file format.
Currently, it is possible to create a plan view or section view object in the model, select it, and run the Export Selected… command. This option has worked for many users, but it has some limitations:
- It doesn’t work when using a real-time plan or section viewport or detail in a layout.
- You need to get your model dirty with these temporary objects, making the display slower and the file bigger.
- You cannot make compositions of different views like in a layout.
- Texts need to be exploded to curves.
- Solid hatches are not supported.
- It’s slow on big files or when there are complex objects (dense meshes or hatches, big curved surfaces, etc.)
What do you need to export to AutoCAD?
- The 3D model (surfaces, meshes, BREPs, curves, etc.)
- The visible lines and section hatches of a plan or section view
- Layouts and details (as seen in Rhino layouts)
0 voters
Why do you need to export your plan or section views to AutoCAD?
- To print the output using AutoCAD
- To have the visible curves in the model-space in AutoCAD and work with them
- To have the visible curves in the paper-space in AutoCAD and work with them
- Other (write your answer as a comment)
0 voters
How are you currently working with VisualARQ plans and sections?
- I use plan-view and section-view objects
- I use real-time plan and section viewports and/or details
- I use both (view objects and real-time viewports)
- I do not use plans or sections
0 voters
Which one of those options will work best for you?
- Export to DWG from the “Levels” and “Sections” panels
- Export to DWG using a plan-view or section-view object
- Export to DWG using a real-time viewport or detail
- Export to DWG using a Rhino layout
0 voters
We’ve discussed several ways to implement this feature. Take into account that not everything can be done. For example, exporting a project to a DWG, with only the 3D objects in the model space, and then some layouts with details inside that show only the plan or section is not possible, as AutoCAD will not compute the project plan/section lines. We need to include these curves in the DWG, so we need to put them in the model and show them using a detail, or we need to fake a detail creating the lines in the layout. Both options have problems: placing curves on the model will make the model dirty, while placing them in the layout will make those curves not have the correct scale. In both cases, panning and zooming will not work, as we will export the curves as they were shown in the Rhino layout.
Thanks,
Enric
