Export 2D dwg from 3D model
Is it possible to export a 2D dwg from my 3D model without first making a plan view. When I try to export from layout view it comes out as a 3D dwg.
Hi @seflorance,
The possibility to export a layout to dwg is planned for VisualARQ 3.
Currently the only way to get a 2D dwg is by creating a plan view or a section view object first.
Kind regards
Ok, thanks Ramon
Hi @seflorance just in case you haven’t seen this yet, you can already try the new feature to export layouts to DWG in VisualARQ 3. You can see how it works here: https://youtu.be/1BhuBbS9gNs
