I am trying to place a number of generic annotations (symbols) in plan view.
I tried using add component location. Is does not fail, but the symbol is not visible in the view.
Thanks
Hi Dbaldzhiev,
No native component yet, here’s a quick python component that will place in a view per point.
PlaceSymbol.gh (10.1 KB)
Also see this python component for placing tags that Ehsan created.
Thnank you so much!
Is there a reason why
if GO:
place_symbol = doc.Create.NewFamilyInstance(DB.XYZ(PT.X,PT.Y,PT.Z),FS,VW)
elements = place_symbol
t.Commit()
instead of
if GO:
t.Commit()
If I use the second option, I can get the elements as output and fiddle with their parameters. If the elements is set in the if case i get <.null>.
No reason why, just copying an pasting the code out of another component quickly. Thanks for pointing that out.
For some reason it places families far away from their intended location. It is probably a unit issue.
