Hi guys,
I was creating revit floors and Add Floor node fails when one of the boundaries fails? Any idea why I am getting this error. It doesn’t create any floor.
Hi guys,
All bundled in one transaction. It may highlight the bad boundary if not can you cycle through and find the offending Boundary? Hard to tell what the error is without seeing the curve.
How can I cycle through it?
I ended up doing with a Python script btw.
You can create a list of indices to pick in the value picker or if you have human loaded you can use the handy Item Selector component and set it to cycle or sequence.
I have about 500 curveloops to loop through. I don’t think I’ll be able to make it.
In that case looping through the branches, or sub list of the branches to narrow it down. Take half, see if it fails, take the other half, repeat until you find the right branch.
I was talking about this with Kike the other day, he’s going to add some info to help identify the bad actors.
Yes, I think it would be great to see the index of the branch/item that fails the transaction.
ok, lots of duplicate rooms and ones that show a closed curve but are like the one below (a separation line)
Sending the details in a private message.
That would be great to see this feature implemented. Im working with creating elements through RiR alot and this used to happen often when managing a lot of curves and shapes, its not easy sometimes to figure out which one of unput data caused thetransaction failure.
As we talked with @Japhy , connecting a surface in the boundary input seems to work too. And it doesn’t abort the transaction.
Thank you for the solution with surfaces, it worked in my case.
I’ve isolated a case where the boundary doesn’t work with curves, if you want to debug it.
Same curves work OK with python. The error seems to be caused by that vertex.
floor curves error.gh (9.9 KB)
@mucahitbgoker Check out the latest Daily build for Error Mode
More details coming, the Default Skip as well as Continue won’t fail everything due to a improper floor curve.
