RIR Create floor plan
Hi
Is there a simple way to create a floor plan in RIR? At the moment I’m getting an existing view, duplicating it and renaming it but I’m hoping there is a more elegant solution.
Nothing too much to add, maybe using a filter or by Name can tidy it up bit.
There is certainly a need for View related components. I couldn’t switch from Dynamo for that kinda tasks.
What additional Components are you thinking? Let’s can prioritize to most generalized ones first.
  • Definitely Creating ViewPlans (floorplan, ceilingplan etc.) from levels
  • Get/Set Crop View
  • Duplicating Views (AsDependent, WithDetailing)
  • Placing Views on Sheets (really popular use for documentation)
  • Isolate in View
  • Set Section Box (for 3DViews)
These are what came to my mind at first.
@parametricmonkey1,
We recently added ‘Add Floor Plan’ to v1.7
@mucahitbgoker,
Also added ‘Add Dependent View’
‘View Extents’ to asjust the view crop extents
And ‘View Section Box’
Thats weird. I am on the latest daily build. But I don’t see those nodes.
Should be available now.
I have noticed that "Duplicate Views with Detailing " is not available with RIR? Is there a component available which I am not Aware of? The workflow that I am following at the moment is duplicate the views as a depended views and converting them into independent views
Hi TTB,
This is an active feature request.
Here’s a quick python version to get you by.
R7-RiR_DuplicateViewWithDetailing.gh (7.0 KB)
Thank you @Japhy
