RiR Linear Dimension automated for all floors
Hello, I am trying to dimension the rooms on all floors at once. I got to the point where the dimensions can be put on individual floors seperately but after that when i am trying to add desired views to the Add Linear Dimension Node, all the dimensions would drop on any one floor. Great thanks if you could help.
dimension_script.gh (24.9 KB)
Hi Shubham,
You’ll want to have matching tree branches when working on multiple views.
Hi Japhy,
The issue that I’m facing is to align those dimensions to there respective levels. as it can be seen in the images below the curves are maintaining there distance from the z axis {image1} but the Detail Lines would scatter over all floors{image 2}. though the final Linear Dimensions maintain their position {image 3}, it gets all messed up in revit.
It’s a branching issue, please use the Param Viewer component and verify that your branches are aligned properly.
I did try and resolve the branching issue but still, I cannot get the linear dimensions in Revit, they have got their element ID’s still they are not visible in any view.
dimension_SS.gh (14.7 KB)
It worked, needed to add Repeat Data.
Thank you, so much.
