Rigid bodies
I’m having an issue when trying to integrate the truss I have drawn into the shell model. this error is occurring:
  1. There are 6 rigid body modes in the system. This means some parts can move freely without causing deformation.
    Try to use the ‘Eigen Modes’-component and activate the display of local coordinate axes: The first eigen-mode will be the rigid body motion.
    If this does not help, check whether you have a pinned support directly attached to a hinge. A hinge introduces an extra node which may cause the problem.
    When analyzing a flat shell structure one has to lock the rotation perpendicular to the plate in at least one node.
    I don’t know how to resolve it.
DOme with pattern.5.gh (88.3 KB)
Hi, make sure to flatten your supports as you have multiple models.
Also using the eigenmodes component you can see that parts of your model are not supported/connected properly
