Hi
Right button not working in Join warning message R8.9
It works fine in the R7 .
Thanks.
I don’t get a join warning message. just “Unable to join curves”
When there is a space between the two lines, this message appears
wait… doesn’t work with preselect, seeing it now
RH-82699 Join popup: right click doesn’t work
What your video shows is the expected behavior.
What your video doesn’t show is whether or not you ended the join command by hitting Enter or spacebar.
Pressing the Yes button doesn’t cause the lines to join. The lines won’t join if you hit escape or start another command without first ending the join command.
