I’m trying to connect Claude AI to Rhino 8 using RhinoMCP but the plugin won’t load.
My setup: - Rhino 8 SR29 (8.29.26063.11001) - Windows 11 (10.0.26200.0) - .NET SDK 8.0.419 installed - Visual C++ 2015-2022 Redistributable already installed - Python 3.9.13 installed - uv/uvx installed and working
What I tried: - Installing via Package Manager (rhinomcp v0.2.1) - Installing via yak.exe from PowerShell - Dragging rhinomcp.rhp directly into Rhino - Running Rhino as Administrator - Uninstalling and reinstalling multiple times
The error I always get: “Unable to load rhinomcp.rhp plug-in: initialization failed” The Details button shows no useful information.
The uvx rhinomcp server works fine in PowerShell, so the Python side is working correctly.
Same issue here, confirming this is still happening on the latest stable release, not just a beta build.
Setup: Rhino 8 SR34, Windows. Tested with “Rhino MCP Platform” via Yak Package Manager:
Beta 0.2.1-wip — fails
Latest stable 0.1.5 — fails identically
Exact error: “Unable to load the RhinoMcpPlatform.rhp plug-in: initialization failed.” The Details button shows no useful info, same as reported above.
I also checked Task Manager for lingering rhino-mcp-router.exe processes in case of a port conflict — none found, so that’s ruled out on my end too.
Would love to know if there’s a known fix, or if this needs a proper bug report to the dev team. Trying to use this for a Grasshopper + Claude workflow for chocolate mold design. Happy to share more logs if it helps.
Hey Callum, hope all good? I’m running into the same wall, “initialization failed” , and can add some data points:
Confirmed on Rhino 8, fully updated to latest release — not a stale Rhino build.
Fails identically on both 0.1.5 (stable) and 0.2.1-wip, ruling out a version-specific regression.
Fails identically whether installed via yak install, Rhino’s built-in Package Manager, or manually dragging the .rhp into the viewport.
dotnet --list-runtimes confirms .NET 8 Desktop Runtime is installed (8.0.2, 8.0.30, plus 9.0.19 and 10.0.11) — so guess it’s not a missing-runtime issue.
Could it be a dll dependency issue?
[PackageManager] Removing inactive version: Rhino-MCP-Platform/0.2.1-wip
[PackageManager] Something went wrong cleaning up Rhino-MCP-Platform/0.2.1-wip: Access to the path ‘e_sqlite3.dll’ is denied.
But I think that is just the connector keeping it running.
