RhinoInside Rhino
Hello
I create a plugin to send some data (like active view, mouse position,…) from Rhino to Grasshopper.
This work fine but the c# component always alive like when we use timer.
Is there a way to make the c# component run only when a new data received from Rhino?
Or maybe a way to receive data without importing the plugin?
Code in the plugin:
using Rhino.Display;
using Rhino.PlugIns;
namespace RhinoToGrasshopper
    public class RhinoToGrasshopperPlugin : PlugIn
        public RhinoToGrasshopperPlugin()
            Instance = this;
            RhinoView.SetActive += OnViewSetActive;
            RhinoView.Modified += OnViewModified;
        public override PlugInLoadTime LoadTime => PlugInLoadTime.AtStartup;
        public static RhinoToGrasshopperPlugin Instance { get; private set; }
        public static string viewname;
        private static void OnViewSetActive(object sender, ViewEventArgs args)
            viewname = args.View.ActiveViewport.Name;
        private static void OnViewModified(object sender, ViewEventArgs args)
        public static void ActiveView()
            using (var args = new Rhino.Runtime.NamedParametersEventArgs())
                args.Set("activeview_name", viewname);
                Rhino.Runtime.HostUtils.ExecuteNamedCallback("RhinoActiveView", args);
Code in Grasshopper:
using RhinoToGrasshopper;  // import RhinoToGrasshopper.rhp
RhinoToGrasshopperPlugin.ActiveView(); // import this from the plugin to enable receiving data
Receive(Component);
Active_View_Name = str;
string str = null;
bool registered = false;
IGH_Component comp = null;
void Receive(IGH_Component component)
  if(!registered)
    Rhino.Runtime.HostUtils.RegisterNamedCallback("RhinoActiveView", RiRhino);
    comp = component;
    registered = true;
void RiRhino(object sender, Rhino.Runtime.NamedParametersEventArgs args)
  string values;
  if (args.TryGetString("activeview_name", out values))
    str = values;
  comp.ExpireSolution(true);
This is an example from Rhinino inside Unity to watch the code
var ghWatcher = new GameObject("Grasshopper Geometry");
ghWatcher.AddComponent<GrasshopperInUnity>();
How we can do the same in Rhino?
