Implementing Event Listening for Custom Grasshopper Components
I want to listen for events from custom Grasshopper components in my application.
E.g. a component with name MyComponent is placed on the grasshopper canvas, then the parameter X (Int Value) has changed.
Now I would like to be notified that the parameter X of the component MyComponent has changed and receive the value of the changed parameter.
Can anyone help me how I can do this? :slightly_smiling_face:
using System;
using System.Threading.Tasks;
using Rhino.Runtime.InProcess;
namespace RhinoGrasshopper
  static class Program
    static Program()
      RhinoInside.Resolver.Initialize();
    [STAThread]
    static void Main()
      using (var rhinoCore =
               new Rhino.Runtime.InProcess.RhinoCore(new string[] { "/NOSPLASH" }, WindowStyle.Normal))
        if (LaunchGrasshopper())
          Console.WriteLine(@"Grasshopper launched");
          Task.Run(() => ListenOnComponentChange());
        Rhino.RhinoApp.MainLoop += (s, e) => { if (Rhino.RhinoApp.IsClosing) Console.WriteLine(@"closing rhino"); };
        rhinoCore.Run();
    private static bool LaunchGrasshopper()
      var grasshopperInterface = Rhino.RhinoApp.GetPlugInObject("Grasshopper") as Grasshopper.Plugin.GH_RhinoScriptInterface;
      grasshopperInterface?.EnableBanner();
      grasshopperInterface?.ShowEditor();
      return grasshopperInterface != null;
    private static void ListenOnComponentChange()
      // Loop....
     // Component param has changed...
Hi Mr. Brunner,
I am not particularly familiar with grasshopper custom components. But could this not be solved by a standard event pattern?
Best,
Chen
Hey,
As chen said, you would need to look into events.
The below will notify you when a new input is plugged into the X coordinate of a Construct Point, but then you would need to do some further work to subscribe to changes to that input and retrieve the value.
        string _componentName = "Construct Point";
        string _parameterName = "X coordinate";
        private void SubscribeToComponentsAdded()
            var doc = OnPingDocument(); // this gets the document in grasshopper, you probably need to do it differently with Rhino.Inside
            if (doc == null) return;
            doc.ObjectsAdded += Doc_ObjectsAdded;
        private void Doc_ObjectsAdded(object sender, GH_DocObjectEventArgs e)
            if (string.IsNullOrEmpty(_componentName)) return;
            var matchingComponents = e.Objects
                .OfType<IGH_Component>()
                .Where(obj => obj.Name == _componentName);
            foreach (var component in matchingComponents)
                component.Params.ParameterChanged += Params_ParameterChanged;
        private void Params_ParameterChanged(object sender, GH_ParamServerEventArgs e)
            if (_parameterName == null) return;
            if (e.Parameter.Name != _parameterName) return;
            DoSomething();
Hope that helps a little
Hi Chen and dchristev
Thank you both for the hints.
I want to use an observer for my approach using the C# delegates / events. The hint with doc.ObjectsAdded += Doc_ObjectsAdded; has already helped me therefore.
I am now taking a brute force approach to wait for the GH_Document. As soon as this is instanciated i subscribe on ObjectsAdded.
In a further step, I subscribe to my own components.
 if (_grasshopperInterface.IsEditorLoaded())
   Task.Run(() => SubscribeToComponentsAdded());
  private static void SubscribeToComponentsAdded()
    GH_Document doc = null;
    while (doc == null)
     doc = Instances.ActiveCanvas.Document;
    doc.ObjectsAdded += (s, e) =>
      // do something
