Rhino viewport rotate/pan/zoom event in Grasshopper
Hi I got an eventlistener to work (based on other threads in here) that check if the active viewport is changed or modified:
  private void RunScript(ref object A)
    A = "Test";
  // <Custom additional code>
  private RhinoView cachedActiveView;
  public Script_Instance() //constructor
    RhinoView.SetActive += OnViewSetActive;
    RhinoView.Modified += OnViewModified;
  // Handle the view set active event
  private void OnViewSetActive(object sender, ViewEventArgs args)
    cachedActiveView = args.View;
    RhinoApp.WriteLine(">> RhinoView.SetActive");
    owner.ExpireSolution(true);
    // You can add more logic here as needed
  // Handle the view modified event
  private void OnViewModified(object sender, ViewEventArgs args)
    if (args.View == cachedActiveView)
      RhinoApp.WriteLine(">> RhinoView.Modified");
However. I wish to subscribe to an event that tracks when I’m zooming, panning etc in the active viewport. Is this possible.
EventListener.gh (4.5 KB)
