Hi ,@Japhy & @eirannejad
I updated to the latest Rhino 8 then all of the sudden I get this error.
What should I do?
What should I do?
Hi @attheeast18,
This use to happen if you update Rhino while is still loaded.
To fix it be sure Revit is closed, Rhino is closed and from Windows installed applications list, repair Rhino installation.
This should update also the Grasshopper.dll that was still loaded last time you updated.
Thanks, Kike
I will do that. I downgraded Rhino 8 so I could work yesterday as a temporary fix. Will get back to you if it works.
